Hello everybody :D
sooo yeah, last week my HX1050 died om me, it just didnt output any power anymore. Luckily i got my money back for the site i bought ut from.
Now i just need a new powersupply, i currently thinking thowards the AX 860i.
You can se my system specs in my sig, i an thinking of upgrading my videocard to a 780 or two in the near future xD.
So anyways, upon purchasing the AX 860i i have a couple of questions,
1: does it require you to plug in the corsairlink cable(The internal USB2.0 cable)?
Because i actually dont have any spare ports, and dont really care much about monitoring the wattage etc.
2: will og be enough with 860w for 2-780s, a overclocked 3930K and a couple of HDDs/SSDs?
I am currently writing this on ny phone (with a stupid Norwegian autocorrect) so please excuse any spelling errors and such :D
Intel 3930K @ 4,4ghz | Asus Rampage IV Extreme | Corsair Dominator GT 16gb | EVGA GTX 680 Classified | Asus Xonar Xense | Corsair HX 1050 | Corsair H100i | Corsair Force 3 120gb | Western Digital 2tb Black |
https://linustechtips.com/topic/32867-help-anybody/
Im sure that is enough watts, as for the usb thing you could buy a usb pci slot and that should work.
Listen if you care.
https://linustechtips.com/topic/32867-help-anybody/#findComment-420255
The 860i should be more than enough for your system.
https://linustechtips.com/topic/32867-help-anybody/#findComment-420270
ok great thanks :D
ehm i dont think that would work, because it uses å internal USB cable
https://linustechtips.com/topic/32867-help-anybody/#findComment-420289
ok great thanks :D
Good luck then, another idea is to get the EVGA supernova 1000w as that decent and I dont think its got the fancy usb stuff that most people cant give two sh**s about.
Listen if you care.
https://linustechtips.com/topic/32867-help-anybody/#findComment-420322
Ok i am now convinced that 860w will be enough, but og ut would be nice if any 860i owners out there could answer my second question before i order? Anyone?
And thanks to everybody how has helped me so far :D
https://linustechtips.com/topic/32867-help-anybody/#findComment-423950
