Front panel headphone connection. Silly question.
I have an ASUS Maximus VII Formula board, which has amazing onboard audio. If I plug my headphones into the front panel headphone jack, though, will they benefit from the back end audio? To me it seems like using a USB 2.0 extension cable and plugging a USB 3.0 device in it expecting the same results.
Assuming I have to use the ports from the board, there is not a dedicated headphone port. Is there a better solution rather than having to unplug my speakers and plug in the headphones?
Thanks!
Desktop: 12900k // 128GB DDR5 // 2x 3070
Laptop: Razer Blade 15 Advanced (2022) // i9 12-900H // 64GB DDR5 // 3080 Ti
No. If you want the on-board Motherboard audio of the Maximus you must plug in your headphones to the REAR ports. (directly into the mobo)
The front panel doesn't quite use the sound card on the mobo, but it also introduces noise, distortion & such.
« Current PC ~ Phantom Beast »
No, Not Really.
9590|EK-Copper|Sabertooth 990FXR2.0|16GB RIPJAWS Z|Dual MSI Gaming 290|Corsiar AX1200i|Corsair 760T|3TB Seagate+Dual 120GB Samsung 850EVO in Raid 0
LTT'S Official Radeon Master Race Club Founder-Predicts TitanX2 (Prediction Date: 3-30-15)
XFX Needs To Make A 3 Fan Cooler
Yeah that's what I was thinking. It only makes sense...
Do you know if there is a better solution than having to unplug my speakers every time I want to use my headphones?
you could get a splitter or hub for the rear ports
:)xD9_9:D:PB|
Ummm, if it isn't using the sound card on the mobo, then where does the front panel got their sound signal from?
