BSOD Help
Solved by ionbasa,
So I just took a look at the dump files and can verify it is the CPU causing the crash. Probably due to your voltage and clock speed combination.
For reference:
Of note: Utilities like the one you posted a screenshot of won't display everything the Windows Debugger is able to display. In specific, the BUCKET_ID, Stack Text, and the full Bug-check String.
Since the "GenuineIntel" module and image is being referenced, the BSODs are likely being caused by an unstable overclock. Either bump down your clock speed or bump up the CPU voltage (or set a more aggressive Load Line Calibration in your BIOS/UEFI).
Windows 8 Kernel Version 9600 MP (4 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSBuilt by: 9600.17668.amd64fre.winblue_r8.150127-1500Machine Name:Kernel base = 0xfffff802`b080c000 PsLoadedModuleList = 0xfffff802`b0ae5250Debug session time: Sun Mar 15 01:15:20.302 2015 (UTC - 4:00)System Uptime: 0 days 1:29:04.909******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************WHEA_UNCORRECTABLE_ERROR (124)A fatal hardware error has occurred. Parameter 1 identifies the type of errorsource that reported the error. Parameter 2 holds the address of theWHEA_ERROR_RECORD structure that describes the error conditon.Arguments:Arg1: 0000000000000000, Machine Check ExceptionArg2: ffffe00158f2a028, Address of the WHEA_ERROR_RECORD structure.Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.Debugging Details:------------------TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2BUGCHECK_STR: 0x124_GenuineIntelCUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULTPROCESS_NAME: StarCitizen.exCURRENT_IRQL: fSTACK_TEXT: ffffd001`f899acf8 fffff802`b0fd7213 : 00000000`00000124 00000000`00000000 ffffe001`58f2a028 00000000`bf800000 : nt!KeBugCheckExffffd001`f899ad00 fffff802`b09d25a9 : 00000000`00000001 ffffe001`552aebc0 ffffe001`552aebc0 ffffe001`58f2a028 : hal!HalBugCheckSystem+0xcfffffd001`f899ad40 fffff802`b0fd76a0 : 00000000`00000728 00000000`00000002 ffffd001`f899b130 00000000`00000000 : nt!WheaReportHwError+0x22dffffd001`f899ada0 fffff802`b0fd7a0d : ffffe001`00000010 ffffe001`552aebc0 ffffd001`f899af48 ffffe001`552aebc0 : hal!HalpMcaReportError+0x50ffffd001`f899aef0 fffff802`b0fd78f8 : ffffe001`552ae810 00000000`00000001 00000000`00000002 00000000`00000000 : hal!HalpMceHandlerCore+0xe1ffffd001`f899af40 fffff802`b0fd7b42 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xe4ffffd001`f899af80 fffff802`b0fd7ccf : ffffe001`552ae810 ffffd001`f899b1b0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xceffffd001`f899afb0 fffff802`b09674bb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40ffffd001`f899afe0 fffff802`b0967271 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7bffffd001`f899b120 fffff802`b08be10e : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x171ffffd000`25ead960 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiTryUnwaitThread+0x13eSTACK_COMMAND: kbFOLLOWUP_NAME: MachineOwnerMODULE_NAME: GenuineIntelIMAGE_NAME: GenuineIntelDEBUG_FLR_IMAGE_TIMESTAMP: 0FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEBUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEFollowup: MachineOwner
Windows 8 Kernel Version 9600 MP (4 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSBuilt by: 9600.17668.amd64fre.winblue_r8.150127-1500Machine Name:Kernel base = 0xfffff800`27076000 PsLoadedModuleList = 0xfffff800`2734f250Debug session time: Sat Mar 14 23:45:30.819 2015 (UTC - 4:00)System Uptime: 0 days 1:02:52.424******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************WHEA_UNCORRECTABLE_ERROR (124)A fatal hardware error has occurred. Parameter 1 identifies the type of errorsource that reported the error. Parameter 2 holds the address of theWHEA_ERROR_RECORD structure that describes the error conditon.Arguments:Arg1: 0000000000000000, Machine Check ExceptionArg2: ffffe001b392e028, Address of the WHEA_ERROR_RECORD structure.Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.Debugging Details:------------------TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2BUGCHECK_STR: 0x124_GenuineIntelCUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULTPROCESS_NAME: Borderlands2.eCURRENT_IRQL: fSTACK_TEXT: fffff800`2911ca38 fffff800`2703d213 : 00000000`00000124 00000000`00000000 ffffe001`b392e028 00000000`bf800000 : nt!KeBugCheckExfffff800`2911ca40 fffff800`2723c5a9 : 00000000`00000001 ffffe001`b01e1690 ffffe001`b01e1690 ffffe001`b392e028 : hal!HalBugCheckSystem+0xcffffff800`2911ca80 fffff800`2703d6a0 : 00000000`00000728 00000000`00000000 fffff800`2911ce70 00000000`00000000 : nt!WheaReportHwError+0x22dfffff800`2911cae0 fffff800`2703da0d : ffffe001`00000010 ffffe001`b01e1690 fffff800`2911cc88 ffffe001`b01e1690 : hal!HalpMcaReportError+0x50fffff800`2911cc30 fffff800`2703d8f8 : ffffe001`afcae6b0 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerCore+0xe1fffff800`2911cc80 fffff800`2703db42 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xe4fffff800`2911ccc0 fffff800`2703dccf : ffffe001`afcae6b0 fffff800`2911cef0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xcefffff800`2911ccf0 fffff800`271d14bb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40fffff800`2911cd20 fffff800`271d1271 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7bfffff800`2911ce60 fffff800`270bfa03 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x171ffffd000`2bdf9730 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiUpdateWsle+0x463STACK_COMMAND: kbFOLLOWUP_NAME: MachineOwnerMODULE_NAME: GenuineIntelIMAGE_NAME: GenuineIntelDEBUG_FLR_IMAGE_TIMESTAMP: 0FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEBUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEFollowup: MachineOwner
Windows 8 Kernel Version 9600 MP (4 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSBuilt by: 9600.17668.amd64fre.winblue_r8.150127-1500Machine Name:Kernel base = 0xfffff800`7e682000 PsLoadedModuleList = 0xfffff800`7e95b250Debug session time: Sat Mar 14 22:41:56.731 2015 (UTC - 4:00)System Uptime: 0 days 2:19:57.338******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************WHEA_UNCORRECTABLE_ERROR (124)A fatal hardware error has occurred. Parameter 1 identifies the type of errorsource that reported the error. Parameter 2 holds the address of theWHEA_ERROR_RECORD structure that describes the error conditon.Arguments:Arg1: 0000000000000000, Machine Check ExceptionArg2: ffffe0011a732028, Address of the WHEA_ERROR_RECORD structure.Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.Debugging Details:------------------TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2BUGCHECK_STR: 0x124_GenuineIntelCUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULTPROCESS_NAME: GTAIV.exeCURRENT_IRQL: fSTACK_TEXT: ffffd001`16dd7cf8 fffff800`7e649213 : 00000000`00000124 00000000`00000000 ffffe001`1a732028 00000000`bf800000 : nt!KeBugCheckExffffd001`16dd7d00 fffff800`7e8485a9 : 00000000`00000001 ffffe001`16aadbc0 ffffe001`16aadbc0 ffffe001`1a732028 : hal!HalBugCheckSystem+0xcfffffd001`16dd7d40 fffff800`7e6496a0 : 00000000`00000728 00000000`00000002 ffffd001`16dd8130 00000000`00000000 : nt!WheaReportHwError+0x22dffffd001`16dd7da0 fffff800`7e649a0d : ffffe001`00000010 ffffe001`16aadbc0 ffffd001`16dd7f48 ffffe001`16aadbc0 : hal!HalpMcaReportError+0x50ffffd001`16dd7ef0 fffff800`7e6498f8 : ffffe001`16aad810 00000000`00000001 00000000`00000002 00000000`00000000 : hal!HalpMceHandlerCore+0xe1ffffd001`16dd7f40 fffff800`7e649b42 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xe4ffffd001`16dd7f80 fffff800`7e649ccf : ffffe001`16aad810 ffffd001`16dd81b0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xceffffd001`16dd7fb0 fffff800`7e7dd4bb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40ffffd001`16dd7fe0 fffff800`7e7dd271 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7bffffd001`16dd8120 fffff800`7e729bca : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x171ffffd000`281c6990 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeReleaseMutant+0x112STACK_COMMAND: kbFOLLOWUP_NAME: MachineOwnerMODULE_NAME: GenuineIntelIMAGE_NAME: GenuineIntelDEBUG_FLR_IMAGE_TIMESTAMP: 0FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEBUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEFollowup: MachineOwner
Windows 8 Kernel Version 9600 MP (4 procs) Free x64Product: WinNt, suite: TerminalServer SingleUserTSBuilt by: 9600.17668.amd64fre.winblue_r8.150127-1500Machine Name:Kernel base = 0xfffff802`ff20e000 PsLoadedModuleList = 0xfffff802`ff4e7250Debug session time: Sat Mar 14 19:37:03.992 2015 (UTC - 4:00)System Uptime: 0 days 20:24:01.598******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************WHEA_UNCORRECTABLE_ERROR (124)A fatal hardware error has occurred. Parameter 1 identifies the type of errorsource that reported the error. Parameter 2 holds the address of theWHEA_ERROR_RECORD structure that describes the error conditon.Arguments:Arg1: 0000000000000000, Machine Check ExceptionArg2: ffffe0017172e028, Address of the WHEA_ERROR_RECORD structure.Arg3: 00000000bf800000, High order 32-bits of the MCi_STATUS value.Arg4: 0000000000000124, Low order 32-bits of the MCi_STATUS value.Debugging Details:------------------TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2BUGCHECK_STR: 0x124_GenuineIntelCUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULTPROCESS_NAME: GTAIV.exeCURRENT_IRQL: fSTACK_TEXT: ffffd000`20381cf8 fffff802`ff9d9213 : 00000000`00000124 00000000`00000000 ffffe001`7172e028 00000000`bf800000 : nt!KeBugCheckExffffd000`20381d00 fffff802`ff3d45a9 : 00000000`00000001 ffffe001`6daaebc0 ffffe001`6daaebc0 ffffe001`7172e028 : hal!HalBugCheckSystem+0xcfffffd000`20381d40 fffff802`ff9d96a0 : 00000000`00000728 00000000`00000002 ffffd000`20382130 00000000`00000000 : nt!WheaReportHwError+0x22dffffd000`20381da0 fffff802`ff9d9a0d : ffffe001`00000010 ffffe001`6daaebc0 ffffd000`20381f48 ffffe001`6daaebc0 : hal!HalpMcaReportError+0x50ffffd000`20381ef0 fffff802`ff9d98f8 : ffffe001`6daae810 00000000`00000001 00000000`00000002 00000000`00000000 : hal!HalpMceHandlerCore+0xe1ffffd000`20381f40 fffff802`ff9d9b42 : 00000000`00000004 00000000`00000001 00000000`00000000 00000000`00000000 : hal!HalpMceHandler+0xe4ffffd000`20381f80 fffff802`ff9d9ccf : ffffe001`6daae810 ffffd000`203821b0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0xceffffd000`20381fb0 fffff802`ff3694bb : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40ffffd000`20381fe0 fffff802`ff369271 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7bffffd000`20382120 fffff802`ff2aa114 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x171ffffd000`21992660 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeReleaseInStackQueuedSpinLock+0x34STACK_COMMAND: kbFOLLOWUP_NAME: MachineOwnerMODULE_NAME: GenuineIntelIMAGE_NAME: GenuineIntelDEBUG_FLR_IMAGE_TIMESTAMP: 0FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEBUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_CACHEFollowup: MachineOwner
