I know this section is called "Troubleshooting" but i couldn't really find another section for this. I need you awesome people to give me some tech I should get under $200. I do NOT want something that computes besides a smartwatch that works with iOS. You can suggest me 2 things or even three that cost $200. Thanks!
https://linustechtips.com/topic/328291-suggest-me-some-tech/
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4456935
Tell us what you're into first, perhaps?..
Audio?
Video production?
Gaming?
Pornography?
Let us know..
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4456938
If you have a Hero camera, buy some stuff for it (I.E, extra batteries, back up housing, and mounts)
A console controller + wireless dongle
I know you said against this, but a Nintendo DS is totally worth considering
Maybe LED strips for around the house?
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4456940
Audio?
Video production?
Gaming?
Pornography?
Let us know..
Thanks for the laugh. I like gaming and audio. I would maybe invest in video but I do not have the "guns" to handle rendering and other things in that sort so to speak.
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4456981
Yeah tottaly forgot that too. Thanks for the shout!
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4457000
snip
snip
a DS or a 3DS?
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4457015
Ahem, well... this is easy.
Go to your computer and hardware store and buy some nice junk you can use to get your SWAG OVER 9000
For example, get some LED strips and a BlueTooth speaker and some nice headphones for you phone or whatever else you might find...
Or you could spend the money buying gems in Clash of Clans... umm, I mean steam games or whatever else you're ahem interested in.
You can also buy some software.
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4457044
How about some good headphones? That would be for Gaming AND Audio. Plus, it would still be in the budget to get an AntLion ModMic - that you can take off & put back on the headphones when you game.
Or if you have some good fidelity headphones, maybe an audio interface to give them a jolt? Would also help in gaming. Or, maybe an Amp/DAC instead?
If not.. What about a GREAT 2nd (or 3rd) monitor for under $200? Get yourself the real "techie experience" with a multi-monitor setup; if you don't already have one.
Another essential I could recommend would be the obvious - a mechanical gaming keyboard if you don't currently own one. Especially if you've never owned one..
Well, there are a few recommendations I could randomly come up with & threw out.
Hope I've helped or inspired you in the right direction!
https://linustechtips.com/topic/328291-suggest-me-some-tech/#findComment-4457107
