Is this a good build for casual gaming in 1080p mid-high settings?
PCPartPicker part list: http://pcpartpicker.com/p/fdm9P6
Price breakdown by merchant: http://pcpartpicker.com/p/fdm9P6/by_merchant/
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($93.89 @ OutletPC)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($44.99 @ Micro Center)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($60.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($44.99 @ Amazon)
Video Card: Sapphire Radeon R7 260X 2GB Video Card  ($102.98 @ Newegg)
Case: Thermaltake Versa H21 ATX Mid Tower Case  ($32.29 @ Directron)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Newegg)
Total: $415.12
https://linustechtips.com/topic/327849-first-pc-build/
Total: $415.12
that system looks pretty good except it's got a pretty crappy Video card. a R9 280 would be a much better bet at a reasonable price bump.
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452162
Total: $415.12
It's okay, don't expect to overclock a bunch with that setup though.  Do you live in the USA?
You can go Intel on that $460 budget.
http://www.hardcoreware.net/intel-core-i3-4340-review/2/
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452166
I dont think i will overclock...At least not yet, im new to this and i dont wnat to damage anything.
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452178
I'd go with this, it's 420 after MIR but it's 470 ish before so hopefully it'll be in your price range.
Motherboard: Gigabyte GA-F2A68HM-HD2 Micro ATX FM2+ Motherboard  ($43.99 @ SuperBiiz)
Memory: Apotop 4GB (1 x 4GB) DDR3-1600 Memory  ($24.99 @ Newegg)
Video Card: XFX Radeon R9 280 3GB Double Dissipation Video Card  ($159.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($19.99 @ NCIX US)
Total: $418.92
Generated by PCPartPicker 2015-03-14 05:14 EDT-0400
No i dont live un USA. WHY do you ask?
He was asking because you linked to the US pcpartpicker and prices vary wildly outside of the US.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452180
'Cause your parts are sourced in US stores.
$480 before rebates:
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($114.95 @ SuperBiiz)
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($49.99 @ SuperBiiz)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($133.98 @ Newegg)
Total: $449.18
Generated by PCPartPicker 2015-03-14 05:16 EDT-0400
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452192
PCPartPicker part list: http://pcpartpicker.com/p/mt8G6h
Price breakdown by merchant: http://pcpartpicker.com/p/mt8G6h/by_merchant/
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($135.75 @ OutletPC)
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($169.99 @ Newegg)
Total: $523.99
Generated by PCPartPicker 2015-03-14 05:17 EDT-0400
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452194
Total: $418.92
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452201
Total: $523.99
Why an 8core?
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452208
when you consider a $60 dollar more part for more performance, it's a big difference.
when you consider a $60 dollar more component for better performance, it's very much worth it.
I know it is a big difference but if i i thought like that i will end up "upgrading" everything in my build.
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452215
Motherboard: MSI A78M-E35 Micro ATX FM2+ Motherboard  ($53.19 @ Newegg)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($52.99 @ Newegg)
Case: Xigmatek Recon ATX Mid Tower Case  ($29.99 @ Newegg)
Total: $435.13
Generated by PCPartPicker 2015-03-14 06:04 EDT-0400
Fujitsu Celsius 380W: i5 650 @ 3.2 Ghz | FUJITSU D2917-A1 | 4GB RAM 1333Mhz | ASUS GTX 750 TI Strix OC Edition | Fujitsu Case | 380W Fujitsu PSU | 250GB HDD | Windows 7 64 bit | Dell P2214H
Rekty Shrekty
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452287
Total: $523.99
No offence but you have to get a much much much better motherboard to run the 8320. That motherboard is horrible. The 8320 is going to be throttled. You have to get a motherboard with a good vrm phase and vrm heatsinks. These are two things which the motherboard you linked, lack. Also by the time you get a better motherboard you could have gotten an i5 4440 and h81 motherboard for cheaper and much better performance, especially in gaming. Not to mention that in most games, even a core i3 4130 performs better than the 8320 while being cheaper,running cooler and using up less power.
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  ($109.75 @ OutletPC)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.98 @ Newegg)
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($37.98 @ Newegg)
Total: $468.67
Generated by PCPartPicker 2015-03-14 06:14 EDT-0400
https://linustechtips.com/topic/327849-first-pc-build/#findComment-4452293
