I have an ASUS A88XM-PLUS, and I have been having problems with the RAM. I have two sticks of 4x2 RAM, and I can't figure out what slots to put it in. Can of you guys help?
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/327729-ram-problem/
1-0-1-0
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450899
Circled in red. You don't have to worry about what goes where cause in your case you have 4 sticks and 4 slots.
CPU: i5-6600k @ 4.4GHz | Motherboard: Asus Z170 Pro Gaming | RAM: 8GB HyperX Fury | GPU: Asus Strix GTX 980 | Case: NZXT Noctis 450 Red/Black | Storage: 256GB Sandisk SSD + 1TB Western Digital HDD | PSU: EVGA 750w | Monitor: ASUS VS247H | CPU Cooler: Cooler Master Hyper 212 Evo | Keyboard: $15 Cheapo Rubber Dome Keyboard | Mouse: Rosewill RGM-300
Linus Tech Tips Pebble (and Pebble Time) notifier watchface!
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450919
I don't get what you are saying, I have DIMM slots A-1, A-2,B-1,B-2
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450920
I have 2 sticks 4x2
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450925
1 is a stick. 0 is no stick.
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450934
I have 2 sticks 4x2
Then you have 2x4GB, not 4x2. Place 1 stick in one slot, next slot is empty, next has a stick and last one is empty. Put them in the slots I colored in red:
You can also put the in the yellow slots, it's up to you.
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450940
Ahh... Didn't know that
https://linustechtips.com/topic/327729-ram-problem/#findComment-4450962
Still not working, says 3.94 out of 4GB usable
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462800
Its working fine, that memory is reserved for you iGP. I have the same thing,
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462867
Its working fine, that memory is reserved by the OS. I have the same thing,
3.94 not 7.94
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462872
3.94 not 7.94
I KNOW. Showing you an Example..
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462886
Wait so 4GB is reserved by the OS?
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462897
The Image is shown is from my system..
Your's has 4GB and shows 3.94GB? So 100mb or less is reserved for the Integrated Graphics.
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462916
It's working fine, that little chunk of "missing" memory is shared with the integrated graphics processor as it has no independent memory
CPU: Intel Core i7 4790K @ 4.8GHZGPU: MSI GeForce GTX 1070 Gaming X (X2 - SLI)RAM: 24GB | Storage: 128GB 960 PRO M.2 SSD, 1TB & 750GB HDD | Operating System: Windows 10, MacOS High Sierra
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462918
I have 8GB
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462929
I have 8GB
Sorry I've read it wrong, my apologies. Check if you've installed the ram properly.
EDIT: Windows 64 bit or 32 bit?
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462987
 64 bit
https://linustechtips.com/topic/327729-ram-problem/#findComment-4462991
 64 bit
Check if you've correctly inserted the ram sticks.
https://linustechtips.com/topic/327729-ram-problem/#findComment-4463000
I have, and I think the slot is broken, because the RAM worked fine on my old mobo.
https://linustechtips.com/topic/327729-ram-problem/#findComment-4463016
