almost everyone is saying that you or us must buy good  headphones not the gaming grade headphones.  should i also buy AMP/DAC to use it properly or just plug it on my computer(speaking of other headphones like audio technica senheiser?)
Equality doesn't mean Justice.
https://linustechtips.com/topic/327432-help-about-headphones/
Don't buy an amp/dac until you've tried the headphones on your onboard audio first. For all you know that might be able to power them perfectly fine.
Also, dedicated headphones will produce a far greater quality of sound as well as sound stage, which is why you should get them over a gaming headset.
Good brands to look at are sennheiser, AKG, audio technica and beyerdynamic, also it depends on your budget and whether you want open or closed cans (open=greater soundstage, closed=better sound isolation)
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/327432-help-about-headphones/#findComment-4447301
There are no gaming grade headphones or headsets. "Gaming" is just a marketing term slapped on to products to make you think it is specifically designed for the benefit of certain scenarios. There's no difference between game audio and other media, so such classifications are pointless.
Amp/DAC is usually unneeded, but what kind of budget do you want to put towards these headphones?
https://linustechtips.com/topic/327432-help-about-headphones/#findComment-4447305
for both: My budget is around the price of Hyper X Cloud 2
https://linustechtips.com/topic/327432-help-about-headphones/#findComment-4453256
Well then, HyperX Cloud is a good option. Don't get the "2" unless your onboard audio is really bad.
Sennheiser HD 518Philips SHP9500Panasonic RP-HTF600-SPioneer SE-A1000, and Takstar HI 2050 (same as the Cloud without mic and has an open back) are good headphone-only options. Add a Zalman clip-on or Moov Mic and you've got a headset.
https://linustechtips.com/topic/327432-help-about-headphones/#findComment-4454447
My board is z87 MSI Pc Mate. will my onboard audio will be sufficient?
https://linustechtips.com/topic/327432-help-about-headphones/#findComment-4481669
