So my friend has been asking me over and over again to recommend her a good laptop that turns CAD well. The problem is I never worked with CAD nor knew much about it so I don't know what to recommend. Does it need a good graphic card? A good processor? Loads of RAM?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/326664-cad-what-does-it-require/
Can you be more specific? CAD just means computer-aided design. Which CAD programs do you intend to use? AutoCAD, Inventor?
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
https://linustechtips.com/topic/326664-cad-what-does-it-require/#findComment-4436991
The problem is she didn't specify what program she uses, likely autoCAD.
https://linustechtips.com/topic/326664-cad-what-does-it-require/#findComment-4437004
Ccad a decent CPU
My dad did cad up to 2008 on a 2nd gen p4
3d rendering of cad lots and lots of CPU power unless you can afford teslas
How about graphics and ram, will a 850 and 16 gigs of ram do good.
https://linustechtips.com/topic/326664-cad-what-does-it-require/#findComment-4437037
for cad drawing sure I would suggest something more beefier just to be on the safe side but its going to fare well with most software. But like I said if they do rendering as well get MOAR POWAH. GPU really doesn't affect anything
https://linustechtips.com/topic/326664-cad-what-does-it-require/#findComment-4437054
Okay well if she's going to be using something like AutoCAD I think just focus on getting a laptop with a decent CPU and enough RAM (8GB or more). If she's going to be doing any 3D stuff, it's gonna need a discrete GPU as well.
https://linustechtips.com/topic/326664-cad-what-does-it-require/#findComment-4437076
