I don't use Aida as benchmarking/stess test in general so I don't know if that is normal for that software. But in general you will see some fluctuation. Which temp you are watching? For single core the jumps are normal when software give different loads per core. If the package jumps around like that its either that software has cycles in stressing or that you should check that mounting. Having cores with up to 10C difference in temps is also normal since thermal paste in IHS isn't smooth.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Benchmarking my 4790k, I realize that the temperature fluctuates a lot.  It can sit at around 65, jump to around 72-74, and then drop back down really quickly.  Is this normal use during Aida 64?  Or is it a sign that I should try reseating the cpu cooler?
Completely normal, and those are good temps for AIDA (not sure where your voltage is at -but the temps are safe).
Nearly all benchmarking utilities will run ~70-80% load briefly in between testing sequences, then blast to 100%. It's a more stressful test, think of it like getting your car to 100, slamming on the brakes to get to 50, then flooring it again.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
