Hello all,
Lately (starting a few weeks ago) I have been experiencing frame drops from 60 down to 30fps on my Gigabyte GTX 970 G1 gaming. This occurs in most games except for CS:GO. I am running the latest drivers and my card temps never reach above 65 degrees Celsius.
The rest of my system is as follows:
Intel Core i5 4590
ASRock H97M-Pro4
Kingston HyperX Fury 8GB DDR3
Corsair CX-750M
Months ago I also had a problem where my PC would black screen during gaming but that problem seemed to fix itself. I am concerned that the current frame drop problem is related to this problem. You may be able to find a link to the black screen thread by searching through my profile.
Any help would be appreciated,
Tofite.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/
-snip-
What resolution are you playing at?
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435124
Hey, tell me this, install GPU-Z, right click at the top where it has the icon at the very top of the window, right click and choose, "Read ASIC quality..." and tell me what the score is... GTX 970s throttle at their ASIC quality...
@Gofspar had to make a bios to fix his, and mine is too high for me to hit it.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435151
Clean reinstall of drivers.
if you're overclocked (which I hope you are, if you have a G1 Gaming) then try resetting it to stock.
Monitor the clock speed with afterburner in the game, this sounds like a case of an overclocking/driver issue setting the clock speed lower than it should be.
Is it random or does it happen after a certain amount of time?  Could you possible run something like 3Dmark to compare your score with similar systems?
4K // R5 3600 // RTX2080Ti
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435154
First of all, I have not really taken the time to OC yet so it's at stock anyways (I'm kind of getting used to the new afterburner with the +0 and so on).
The frame drops happen at random intervals.
I will attempt a driver reinstall this afternoon (I'm in Australia) when I return home from work.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435188
I do upscale some games though (play at higher res) as I don't have the money for a new monitor at the moment.
Upscale by how much?
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435213
I usually upscale to 1920x1200 16:10.
In that case, I'd follow Darkman's instructions.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435240
Will do as soon as I return from work.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435249
Set the RAM speed to the max speed manually, that fixed it for me and I have pretty much the same system as you (i5 4570, G1 Gaming 970, Hyperx Fury 8GB/2 4GB sticks).
I set it to 1600Mhz and boom.
EDIT: Do that in the Mobo BIOS:
When I built the PC I checked the speed and both DIMMS were at 1600Mz.
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4435277
Turn vsync of. And crappy games or high aa in combination with scaling/dsr can cause framerates below 60fps, with vsync that means 30fps.
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4440277
The ASIC quality of my card is 59.2%....is this good?
https://linustechtips.com/topic/326520-gtx-970-frame-drops/#findComment-4448373
