https://linustechtips.com/topic/326444-help-on-pc-build/
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434035
What are you going to be using the computer for? You could save on the motherboard for sure. I would also put in an SSD for the OS. Also get a PCIe Network card if you're going wireless.
CPU: i7-4790K --- HEATSINK: NZXT Kraken X61 --- MOBO: Asus Z97-A --- GPU: GTX 970 Strix --- RAM: 16GB ADATA XPG --- SSD: 512GB MX100 | 256GB BX200 HDD: 1TB WD Black --- PSU: EVGA SuperNova G2 --- CASE: NZXT H440 --- DISPLAY3 x Dell U2414H --- KEYBOARD: Pok3r (Clears) --- MOUSE: Logitech G Pro --- OS: Windows 10
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434041
Here a PC Part Picker list (with the video card) for you to edit:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($222.75 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.98 @ OutletPC)
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard  ($239.99 @ Micro Center)
Video Card: EVGA GeForce GTX 980 4GB ACX 2.0 Video Card  ($534.99 @ Amazon)
Case: Corsair 500R White ATX Mid Tower Case  ($89.99 @ NCIX US)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  ($35.98 @ Newegg)
Wireless Network Adapter: Asus USB-AC51 802.11a/b/g/n/ac USB 2.0 Wi-Fi Adapter  ($42.27 @ Amazon)
Monitor: Asus VN248H-P 23.8" Monitor  ($135.98 @ Newegg)
Total: $1631.76
Generated by PCPartPicker 2015-03-11 18:58 EDT-0400
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434125
For gaming you'll be great with that 980 at 1080p for a while. I changed it to something with a cheaper motherboard that fits your black and white theme. Getting a $240 mobo isn't really necessary. I also added an SSD and PCIe network card that I personally am using. I really recommend getting one just for overall OS speed.
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($99.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ Adorama)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.76 @ OutletPC)
Total: $1056.25
Generated by PCPartPicker 2015-03-11 19:03 EDT-0400
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434173
Haha. I was in the middle of putting it together. Thanks bro. So what do you think? Good for high setting gaming?
quote the guys posts by hitting multiquote makes it easier for us to see your posts and dude this thing will be a beastttttttt of a gaming machine.
askdjfasdf
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434176
Total: $1056.25
Thank you very much Spenser_I!! Definitely on my budget! Going to be ordering the parts soon since I'm on break. In the future I'll post a photo of the build.
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434243
Hey there. I'm fairly new to PC building. I would like some insight or advice on this build that I plan to do. I went to Pax East 2015 and won an Evga Geforce GTX 980 SC Acx 2.0 and so that reduced a butt load on the budget. I don't want to spend more than $1400 on the build, excluding the graphics card. This will be running on Windows 8.1 64-Bit. Thanks for the help, greatly appreciated.
PC Build:
lucky winner, I suggest an SSD and an i7-4790k if you are using it for content creation as it has hyperthreading
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4434838
Total: $1056.25
The 500R doesn't have a window (Only mesh) so colour coordination doesn't really matter.
https://linustechtips.com/topic/326444-help-on-pc-build/#findComment-4441002
