So I'm planning a new build soon with a seasonic 860w and 2 780s. And going to sleeve and make custom cables. Just wondering if I can y-split my pcie cables to reduce cable clutter. ie so I have 1 pcie 8pin and 1 6pin coming out from my PSU then both spliting into 2 to each of my 780s.
https://linustechtips.com/topic/32623-custom-sleeving-and-cables/
NO! you will fry your card/PSU/ it won't work. Each cable provides an amount of current, needed by the card, that's why it uses 4 sets of cables/connectors for 2 cards, that's their power draw. If they needed 300w, and you gave them half? The psu is single rail, but i don't know, this seems fishy...
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/32623-custom-sleeving-and-cables/#findComment-416992
Don't do it you will overload you cables and they will burst on fire, each set cable can only take a certain amount of current and combining two cables worth of power into one is likely to overload the cables.
Inside the psu is a central solder point for a +12v, +5, etc. if you had thicker cable soldered to this point i don't see why you couldn't do it.
The 780 TDP is 250 w, since a 8 pin pcie can supply 150w and a 6 pin can supply 75w, plus the pci slot can supply 75w, its a total of 300w the card can use so if you split the 6 and 8 pin you supply a total 187w to the card and thats not enough.
https://linustechtips.com/topic/32623-custom-sleeving-and-cables/#findComment-417306
