Difficult Networking Problem?
Solved by lions240,
You would have to go into your router and block HTTP and HTTP in restrictions. You want to block it only for that device and not all the devices so I would statically assign the IP to the system and add the restrictions to the statically assigned IP. This will allow the computer access the local network and not be able to access the Internet.
