Case Question
By
silverlight
in Power Supplies
in Power Supplies
Solved by Atmos,
You might need a shorter power supply if I'm correct. That's a full sized psu in an itx build, which is usually uncommon.
The itx case you want has lots of options most don't. You're fine.
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
