So I've decided to add some tech stuff to my YouTube channel. I decided for the first one I'd do a $700 PC. I figured maybe you guys could help me improve it and its prices?
http://pcpartpicker.com/p/rPpnFT
PC and Peripherals:
Intel Core i3 4150 @3.5GHz - ASRock H97M Anniversary - Kingston Fury HyperX Black 8GB DDR3 @1866MHz - Gigabyte GeForce GTX 960 G1 Gaming 2GB GDDR5 - EVGA 500W 80+ Certified - WD Caviar Blue 1TB - WD Caviar Blue 160GB - Lian Li PC-50 - Linux Ubuntu 14.04.3 LTS - Acer P221w 21.5" 1680x1050 60Hz - Kingston Fury HyperX Clouds - Razer Deathadder 3.5G - CM Storm Quickfire Rapid w/ Cherry MX Blues
https://linustechtips.com/topic/325088-planning-tech-channel/
Some suggestions that I will explain.
  • A better cpu because the budget allows for it and it is not that much more
  • A less expensive motherboard. The motherboard is not going to be taxed, so little need for anything fancier.
  • An ssd. Even though the Kingston V300 is not a great performer, it is still vastly superior to hdd for booting, browsing, and general work.
  • A slightly better gpu, mostly to get the power requirements down.
  • A less expensive, but decent case.
  • A pedestrian psu that is pretty good for the price.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($187.95 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($61.98 @ Newegg)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory  ($59.99 @ Adorama)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($51.88 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.97 @ SuperBiiz)
Video Card: EVGA GeForce GTX 960 2GB Superclocked Video Card  ($199.00 @ NCIX US)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($38.99 @ NCIX US)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($47.99 @ Amazon)
Total: $695.75
Generated by PCPartPicker 2015-03-09 15:26 EDT-0400
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4415731
Total: $695.75
Drive bays may be blocked..I agree on the motherboard, no need in getting a slow SSD; and it generally isn't needed. I agree completely on that GPU to be honest, but the last thing is that the CX units are not the greatest quality, and that certainly wouldn't leave room for future upgrades. The XFX unit is quite a bit better for the same price.
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4416160
Updated build: http://pcpartpicker.com/p/MnmjK8
Thanks for the help. It should be quite a bit better with that CPU. I may change the motherboard to the Anniversary edition. This is also around the same price now.
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4416182
You can refer this for help
http://pcpartpicker.com/b/7m3Ff7
Thanks man! I like that Arc 100.
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4416666
The Shinobi case is ATX. The motherboard is mATX. It would be better to either switch to an mATX case or select an ATX motherboard.
SSD make systems much more responsive. Even a "slow" ssd is significantly faster than an hdd. The only reason not to include one in a build is because there is no way to squeeze it into the budget. If the budget allows a better ssd would be a good idea.
Many people malign the CX psu. They are in fact quite good. Especially at their price point. http://www.legitreviews.com/corsair-cx430m-modular-power-supply-review-what-25-can-buy_2169/8.
The XFX psu is non-modular which is why I don't particularly like it. It is also $9 more expensive. (The non-modular CX-430 is almost $20 less expensive than the XFX. But you are right, the XFX unit does provide a little more room for upgrades and is good.
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4416692
I'll change the motherboard to the ATX version.
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4417317
I worked on the build some more:
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($186.56 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($68.98 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Vapor-X Video Card  ($235.59 @ Amazon)
Case: BitFenix Shinobi Window ATX Mid Tower Case  ($53.99 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($43.99 @ NCIX US)
Total: $693.99
Generated by PCPartPicker 2015-03-12 16:17 EDT-0400
Thoughts?
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4441094
What's your channel?
YoshiTheFox. You can tell I'm quite young but I do enjoy PC's. :P (Because my voice is a bit higher.)
PC and Peripherals:
https://linustechtips.com/topic/325088-planning-tech-channel/#findComment-4443159
