Top mounted Power supply's
CM7
Just a thing I was wondering why are so many cheap cases have the top mounted form factor and what the advantages/disadvantages of a top mounted PSU.
Overkill Chill:
CPU: Intel® Core™ i5-3450 CPU with Hyper 212evo | RAM:  2 x 4 GB DDR3 MoBo: ASRock H61M-DGS R2.0 | PSU: Rosewill PHOTON 750W | GPU: SAPPHIRE DUAL-X R9 280 3GB | Case: Antec One Gaming | Storage: Kingston HyperX 120gb, Seagate 2 TB | OS: Windows 10 | Displays:  Asus VS228H-P, Hp 2009m
well your psu fan will blow on your motherboard
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
Helps with exhausting hot air usually since most of those cases don't have the best ventilation, the main benefit of having a bottom mounted PSU is to make the case bottom heavy so it won't tip over easily if someone was to knock it.
@CM7, you could turn it round so it does not blow on the motherboard and drill "NEAT" holes in the top so air can flow though.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
That's not how PSU fans work. PSU fans pull air into the PSU and push it out the back.
Wrong way. The PSU fan is an intake, not exhaust, so it will be pulling air away from the motherboard.
They put them up there because cases used to be made that way to make sure that is actually got airflow, as quality and efficiency wasn't as good as it is now, but OEMs still have cases that way round so it's easy to sell cheap ones with that orientation.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
o
Dell Inspiron 3147
  that makes sense for the cheap cases to be used in builds that don't require a lot of air flow.
Never thought of that! Lol PC modding like a boss.
Overkill Chill:
