Hey all, I got myself a custom PC in July 2014 that was built by the website I bought the parts from (ijk.com.au) and have quickly filled up my 1TB hard drive. Since it was built by them, not many cables came with the computer, only some PCI-E and molex to another cable. I'm not too familiar with hard drives, and would like some links to SATA data and power cables on pccasegear.com and ijk.com.au . Thanks :)
https://linustechtips.com/topic/324177-second-hard-drive-help/
I should be studying.
https://linustechtips.com/topic/324177-second-hard-drive-help/#findComment-4404184
Thanks guys, but as I said I'm not familiar with hard drives and their cables so I'm not sure which are power or data cables. I see one labeled as "Astrotek Slim SATA and SATA power cable", but I'm not sure if the fact that its slim affects anything.
https://linustechtips.com/topic/324177-second-hard-drive-help/#findComment-4404208
The power cable is on your power supply, you don't buy a SATA power cable. Those are data cables. Slim doesn't matter. It is just slim.
https://linustechtips.com/topic/324177-second-hard-drive-help/#findComment-4404214
