Yes.
https://linustechtips.com/topic/324173-question-about-usb-hub/#findComment-4404142
latency is affected very much depending on USB hubs. I had a targus AND IT WOULD GLITCH OUt when i plugged in my keboaard/mouse into one port and spam all the keys and almost broke me laptop ):
OFF TOPIC: I suggest every poll from now on to have "**CK EA" option instead of "Other"
https://linustechtips.com/topic/324173-question-about-usb-hub/#findComment-4404159
I recommend a powered one I have had questionable performance with unpowered USB hubs.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/324173-question-about-usb-hub/#findComment-4404471
Also get a usb 3 one if you can.
System Specs
https://linustechtips.com/topic/324173-question-about-usb-hub/#findComment-4405685
