Hi, just wanted to say, if u got an old fan, that is not electrically fried, and does not spin, u can clean it gently from the dust, just don't get the inside wet, then pull off the logo sticker, then do a little more cleaning, then take out the rubber cap, clean the inside as much as u can gently to not damage the pin, (industrial cleaning spray is best), then put in a drop of high grade oil, move the fan gently up and down and spin it gently, the oil will spared, now clear any oil leftovers, then put the rubber cap back on, more cleaning, then put a custom sticker on, u can save the fan. (I tried it with olive oil, the lowest grade, it held a  week, two if ur lucky and run it 24/7 the higher the oil grade the longer it will stay alive), hope u enjoy messing around with some old fans, :) and or I helped u and or u lyao   :).
When i'm not playing PC games i'm playing with my PC parts  Fans,Pumps,Filters,  :wub:  :wub:  :wub:
https://linustechtips.com/topic/324056-fixing-a-fan/
