So my main usage for the mic's (mentioned later) is doing voiceovers, and maybe in the future, further audio needs for my DSLR. Which mic makes more sense
For this mic, i have a question, can i use it with a pc?
For this mic, how's it for podcast/voiceover usage?
Please help
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/324049-mic-help/
what camera is this for?
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/324049-mic-help/#findComment-4402428
Canon T5i
https://linustechtips.com/topic/324049-mic-help/#findComment-4402434
Overall...I guess the condenser...
lol wich one? They both say condenser
https://linustechtips.com/topic/324049-mic-help/#findComment-4402438
-snip-
Neither will be wonderful I can tell you right now...
But for voiceovers the condenser, for dslr the second... choose what you want more. I'd recommend saving for a Blue for cardioid or Rode for shotgun...
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/324049-mic-help/#findComment-4402450
The one that says condenser earlier in the title...
The first one? The AGPtek?
 Can i use that with a pc?
https://linustechtips.com/topic/324049-mic-help/#findComment-4402452
This is something i need urgently for a project we're doing next week.  So if i use the condenser AGPtek one, can i also use that on my dslr, or is that just stupid?
https://linustechtips.com/topic/324049-mic-help/#findComment-4402462
You can't use either without an interface.
Edit: And you can't mount that to a camera without some serious hackjob, as most of those type mics need a +48 input.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402467
Like a Preamp?
https://linustechtips.com/topic/324049-mic-help/#findComment-4402471
Like a Preamp?
No, a dedicated audio interface, one capable of pushing +48v phantom.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402488
Crap, this stuff is getting complicated..
So in your opinion, for my needs what is the simplest thing i should get?
https://linustechtips.com/topic/324049-mic-help/#findComment-4402499
The shotgun, and just put in on a hotshoe, but can the T5i even take XLR?
https://linustechtips.com/topic/324049-mic-help/#findComment-4402503
The cable's a XLR to 1/4" jack, and it comes with an adapter to normal 3.5mm one that the t5i takes
But i can't use that on a pc right? Any other suggestions that work with both pc and dslr?
ALSO, i believe none of the mics need phantom power because they each need dedicated batteries.. or did i understand phantom power completely wrong
https://linustechtips.com/topic/324049-mic-help/#findComment-4402509
If it's a 3.5mm it can be taken on input... but I wonder if it receives power from the camera itself.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402516
the mic uses AA battteries
https://linustechtips.com/topic/324049-mic-help/#findComment-4402520
Then you're fine, and it'll work by plugging into input.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402554
Does that mean the first AGPtek mic will work the same way as well? A question i have about that one is if i mount it on a boom pole or something that's above the subject (if i do home movies etc.) will it sound good? Also, some people recommend a pre-amp/headphone amp for both mics
https://linustechtips.com/topic/324049-mic-help/#findComment-4402564
Probably not. I doubt the first mic is battery-powered... And in every proper mic I've ever used (a lot), it takes phantom power.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402586
Just wondering, what is phantom power in this case? Is it USB? Because there is a XLR to USB cable for this mic as well, wondering if that will work
https://linustechtips.com/topic/324049-mic-help/#findComment-4402625
I don't use USB mics... but if the USB port is powered I suppose it could work.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402659
le' this one
http://www.amazon.com/Microphone-female-meters-AGPtek-Reader/dp/B005HH2GCQ/ref=sr_1_10?s=musical-instruments&ie=UTF8&qid=1425776931&sr=1-10&keywords=AGPtek
Btw thank you so much for your help so far :D
https://linustechtips.com/topic/324049-mic-help/#findComment-4402673
Theoretically it will work... but I can't guarantee it. I only use XLR mics on interfaces.
https://linustechtips.com/topic/324049-mic-help/#findComment-4402698
