Hey guys I downloaded memtest86 latest version here http://www.memtest86.com/download.htmto a usb drive, boot it, ran the program, and after a while it wouldn't pass a test, the number on pass stuck on 91% and test stuck on 16% it wouldn't go any further. I use windows 8 pro, am I doing something wrong here?
Also is there any difference between memtest86.com with memtest.org???
https://linustechtips.com/topic/323743-memtest-is-stuck/
Thats the memtest i use! This may point towards a issue with ur RAM or just try remaking the boot drive u may have a faulty download, also have u left it going for a few hours i normally leave mine going for 6-7hours
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/323743-memtest-is-stuck/#findComment-4399028
