For anyone who uses OBS can you all recommend me settings that will prevent more lag on my computer or if possible have no effect on the game i am playing. When recording/streaming the audience should be able to read text on screen and I must record and stream at the same time playing A3L. also my upload speed is this: http://www.speedtest.net/my-result/4194398663. Also will the bit rate effect my computers performance? also can you give any outside computer advice that will help me get better frame rate in games that is VERY CPU intensive. Thanks so much!
System:
  • CPU
    AMD Phenom II X4 965
  • Motherboard
    ASUS m5a97 r2.0
  • RAM
    8GB DDR3
  • GPU
    MSI R7870 Twin Frozr 2GD5/OC Radeon HD 7870
  • Case
    Cooler Master
  • Storage
    120GB Samsung, 500GB HDD
  • PSU
    Corsair TX750
  • Operating System
  • Windows 7 Home Premium x64
https://linustechtips.com/topic/323264-obs-no-lag-setting/
