when im playing dying light im only getting 50-60fps on ultra settings.
I have 2 gtx 970s, When im playing gpu1 is at 70% usage and gpu2 is at 50% usage but my cpu is at 80% usage (intel i7 4790k)
Does anyone know why i am getting low gpu usage but very high cpu usage.
https://linustechtips.com/topic/323218-dying-light-fps-problem/
There are a lot of settings you can tweak.
There are the two Nvidia only setting in the game, try disabling the Depth Of Field setting.  I read that does a number on your FPS, and is pretty useless.
Further, you can lower draw distance... please tell me you did not slide the bar to the right.
...and lastly, there is a program called Dying Light Manager that allows you to finely tune the video settings.
https://linustechtips.com/topic/323218-dying-light-fps-problem/#findComment-4392611
