Hey guys im getting a ssd for windows and a cupple of games
Q1: How will i still get all my steam games from my hd if i boot from windows
Q2: How do i transfer only a cupple of games aswell as my os
For Q1. When you install Steam Games, it gives you an option on where you want to install them. You just select your HDD instead of SSD. I just made a place in my HDD called (Program Files (x86) and just installed game there.)
For Q2. I just re-installed windows because it was easier for me at the time. It is up to you, someone might know an easy way to do it.
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/323076-hd-to-ssd-help/#findComment-4390913
Thanks alot :D
https://linustechtips.com/topic/323076-hd-to-ssd-help/#findComment-4390956
Thanks alot :D
No problem, good luck  :lol:
https://linustechtips.com/topic/323076-hd-to-ssd-help/#findComment-4390966
