Is it viable
Does it give perfect scaling?
Its been a while since I have used Blender, but I don't think it supports SLI or CFX since neither of those technologies cater for a professional environment. If Blender supports GPU assisted rendering, I would imagine that it could take advantage multi GPU set ups, but it would all depend on the renderer you use.
https://linustechtips.com/topic/322859-multi-gpu-for-blender/#findComment-4388143
Cycles render
https://linustechtips.com/topic/322859-multi-gpu-for-blender/#findComment-4388167
There is no such thing as SLI scaling in blender. If I wanted to I could use a GTX 660 and a GTX 970 (I have both just don't have the motherboard...) to render the same image, each rendering a block. Using multi GPUs should in fact multiply by each (same model) GPU, if your CPU can feed all at the same rate. I'd suggest reading this article to set-up cycles to render properly on your GPU:
http://www.blenderguru.com/articles/4-easy-ways-to-speed-up-cycles/
(mainly look at tile settings)
(3x 590 GTX running at the same time which in total is 6 GPUs)
The reason it would not scale properly is because in each tile there are different amounts of detail which means it takes longer in certain sections of an image than others. With multiple GPUs running at once each GPU would have a different load amount causing for each GPU to finish a tile at different rates.
Hopefully this wasn't confusing lol :)
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
https://linustechtips.com/topic/322859-multi-gpu-for-blender/#findComment-4391802
