There are two available drives for my crap integrated graphics. The two intel drivers are released on the same day and or nearly identical except for the fact that one says "This driver is intended for developers and IT professionals." What is the difference between this driver and the normal one?
PC SPECS: Athlon 860k, MSI 380 4GB, 8GB memory, 1TB HDD, Fractal Design Core 1000
https://linustechtips.com/topic/322843-driver-help/
well correct me if I'm wrong, but you can go to device manager, find the integrated graphics card and use "update drivers". i think it will choose the one you need
if not then i suggest using the driver that doesn't say "for IT professionals", due to the fact that (i assume) your a normal PC user.
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/322843-driver-help/#findComment-4388080
Thanks. I know a lot about computers but I didn't know if the "IT" one provided more options for PC "geeks" like myself
https://linustechtips.com/topic/322843-driver-help/#findComment-4388129
