Just got my new ISP set-up with FTTC.
On my Laptop (Wireless), Phone (Wireless), other Phone (Wireless) and other Desktop Computer (Ethernet Cable (cat5)) I am getting 37Mbps download and 16Mbps Upload.
However on my main computer (Ethernet Cable (cat6) I am getting 37Mbps download and only 7-8Mbps upload. I have been doing multiple tests on speedtest.net and on different servers.
I have tried the cat5 Ethernet cable from the other Desktop Computer.
I have also tried a USB to Ethernet Adapter with both the normal cat6 and the cat5 cable.
I can't seem to understand why I am getting such little upload on my computer.
I am Running Windows 8 Pro 64bit, so is the laptop. the other PC is running Windows 7 Ultimate 64bit.
Intel i7 4790k | Corsair H110i GTX | MSI Z97S Krait | 16GB HyperX Fury | ASUS Strix GTX 970 | Samsung 850 EVO 120GB SSD | Seagate 1TB Hybrid SSHD | WD 3TB Green | Corsair TX750M |
Corsair Graphite 760t White | 3x AOC i2267Fwh 21.5 inch IPS Monitor 1080p | Corsair Raptor k50 RGB | Logitech G500 | Blue Snowball
https://linustechtips.com/topic/322392-strange-network-speed-issue/
Perhaps background usage from programs you have, monitor the usage and see what's using your NIC.
Although it's unlikely to account for the entire difference, although it could reveal malicious software or bad drivers. Checking your mb manufactures website for any updates in drivers or look up the nic manufacture directly for new drivers.
Off the top of my head I can't think of what could account for this apart from the mentioned above, if everything checks out perhaps investigate a possible fault in the system. Such as hardware damage or issues with heat.
I hope that helps you track down the reason, let us know if you discover the cause and post the results of your diagnostics perhaps some one will recognise something from experience.
