Hey guys!
My main question is about PWM. I just bought a couple of PWM fans and I was wondering how they would work with the integrated fan controller of the Corsair Graphite 760T.
Would I be better off hooking the fans directly to the mobo?
Thanks in advance guys!
"Our conversations aint long, but you know what is." - Jason Derulo
https://linustechtips.com/topic/322277-fan-controller-and-pwm/
No but you won't be able to control them separately.
But is not the point of a fan controller to control separately each fan individually at its own channel ? ._.
Grant us the joy of song and dance and ever watch over us in the lonely places in which we must walk - Pray to Bastet
https://linustechtips.com/topic/322277-fan-controller-and-pwm/#findComment-4394057
Not in this case, this built in fan controller controls the speed of 4 fans at once with one button unlike 5.25" bay controller which can control 5-6 fans separately.
https://linustechtips.com/topic/322277-fan-controller-and-pwm/#findComment-4394273
Got it! Thanks guys! Now, how does a PWM fan splitter work? Won't it show up on my computer as only 1 fan since it would be plugged into 1 PWM header?
Edit: Oh and also, how do I control the PWM fans once they are all hooked up? Fan control software?
https://linustechtips.com/topic/322277-fan-controller-and-pwm/#findComment-4397183
Yes, it will show up as 1 fan but if you follow the instructions I posted before both pairs of radiator fans will be controlled separate from each other. You can control them in the bios or if you find good fan control software.
https://linustechtips.com/topic/322277-fan-controller-and-pwm/#findComment-4397656
Got it! Thank you! Already ordered my splitter on amazon!
https://linustechtips.com/topic/322277-fan-controller-and-pwm/#findComment-4397690
