Hi,
I was wondering if you could help me on a question I have.
Here is what I bought:
Case:  Node 304
Mobo: H87i-Plus
CPU:   G3258
GPU:   R9-270x (MSI)
I was supposed to get the "Be Quiet! Pure Rock" as a cooler wich would have fitted nicely.  But I got the "Be Quiet! Shadow Rock 2" by mistake.
Can I leave fan out as long as my temps don't go too high?
Will they go too high?
(If they won't go too high) If I overclock the cpu, will the temperture stay reasonable?
Thanks in advance.
PS: The exhaust fan of the Node 302 is less than 1 cm away from the heatsink.
https://linustechtips.com/topic/322158-node-304-cooling/
Yes u can leave the fan out. As you can't over clock that CPU with that mono anyway
CPU: I5-4440 / MOBO: Gigabyte GA-Z87-DS3H / RAM: G.Skill ripjaws 2x4GB / Storage: Samsung 840 EVO 128gb SSD, 1TB WD HDD / PSU: Corsair CX500M / Case: Xigmatek Aquila / Monitor: Dell U2414H
https://linustechtips.com/topic/322158-node-304-cooling/#findComment-4378964
Hello again,
For all I heard, the mobo does support overclock?
NCIX site says:
http://www.ncix.com/detail/intel-pentium-g3258-anniversary-unlocked-d2-97890-1423.htm
ASUS site says:
H87I-PLUS BIOS 2001 and BIOS updater
Support Intel® Pentium® Anniversary Edition CPU (G3258).
PS Haven't tried overclocking yet, just trying to put it together...
https://linustechtips.com/topic/322158-node-304-cooling/#findComment-4379096
