Silent modular PSU
Go to solution Solved by pomaranc,
EVGA 750G2 is slightly better than corsair RM 750 ;)
I need a power supply for my build, it has to be modular and very silent, my current one is never silent and gets really loud when playing any game, I might have gotten a bad one, but I don't want to go through all the trouble and RMA.
Budget: 100$-130$
Current PSU: XFX 650W
Build:-
Motherboard: Gigabyte GA-Z97X-Gaming 5 LGA 1150
HDD: 2x WD Blue 1TB SATA 6Gb/s 7200rpm
SSD: Intel 530 Series 240GB
GPU: EVGA GeForce GTX780 Superclocked 3GB
CPU: Intel Core i7-4790k
RAM: Corsair Vengeance 16GB (2x8GB) DDR3 1600MHz
So what do you guys recommend? ^^
https://linustechtips.com/topic/321775-silent-modular-psu/
its actually ALOT BETTER
the RM uses jap caps on the main stuff but cheap chinese and taiwanese caps on the secondayry stuff, while the EVGA used 100% japanese caps
dont go RM plz
Corsair RM 750 seems like a good one, I'm ordering one next week.
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373816
dont go RM plz
Are there any other power supplies around the same price as the RM, 750w with all flat cables you could recommend? I would prefer a flat cabled modular power supply for easier cable management. :P
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373830
the EVGA 750 G2 has all flats cables exept the 24 pin mobo connector
o shit wait it doesnt, all of the cables are bundled with sleeving (its pretty nice sleeving BTW) but all the calbes are black, even the 24 pin  but if you want Cable Mod sells kits for that PSU
http://cablemod.com/products/?filter_models=24
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373834
I can only order from Amazon.com, so it's better if it's available with amazon prime, and the EVGA 750G2 is a bit expensive...how about the 650G1? ^^
the 650 g1 is still a solid choice, not as high qualty as the G2 but totally higher quality than the corsair RM
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373870
850G2 is excellent PSU but it is overkill for your PC unless you plan to SLI.
i think 750 is plenty for SLI 780s
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373995
No plans for SLI :/
What about the B2? 750B2...good price, and semi modular is fine.
yea its a good budget choice
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4373997
Found the 750G2 on amazon.co.uk with prime, will either order it from there or order the 750B2 from Amazon.com
Thanks for the help ^^
how come it's a lot cheaper from Amazon.co.uk?
http://www.amazon.co.uk/EVGA-SuperNOVA-750W-Power-Supply/dp/B00J01K3E8
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4374078
Which Country are you in ?
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4374116
G2 PSUs have 0RPM mode, I am not sure if B2 have it but probably not.
and g2 are 80+ gold while the b2 are 80+ bronze, and the G2 cables are all black while the B2 has yellow and red cables
https://linustechtips.com/topic/321775-silent-modular-psu/#findComment-4374160
