That is a tricky one. UK or the US? (or somewhere else?  :blink:)
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/321681-wireless-usb-hub/#findComment-4372587
Is that what you are looking for? It is a bit expensive (and big) but I think it is what you want? http://www.iogear.com/product/GUWIP204/
EDIT -
Found it on NewEgg for cheaper: http://www.newegg.com/Product/Product.aspx?Item=N82E16817399103
https://linustechtips.com/topic/321681-wireless-usb-hub/#findComment-4380351
EDIT -
seems like it. i am looking for something that i can use to connect a keyboard and mouse (and maybe a screen as well?) to so that i do not have to move my whole pc when my friends come over.
https://linustechtips.com/topic/321681-wireless-usb-hub/#findComment-4382559
Ahh fair enough. Sure enough it is easier to move it than spend that much money on it? (or get really long USB extentions?!)
https://linustechtips.com/topic/321681-wireless-usb-hub/#findComment-4382602
