7970 overclocking advice please
Hi
Overclocked my msi boost edition 7970 to 1125mhz on the core and 1575mhz on the memory and set power limit to +20% using msi after burner but once I dial this in the voltage is then constantly 1.256V instead of dropping down at idle is this normal and is there a way I can change it so it will drop the voltage at idle? Does it matter will it use much more power? It raises my idle temps by ~7-10 degrees too. This overclock was tested to be stable no visible artifacts if I raise the core to 1150mhz artifacts are clearly visible during benchmarks.
Thanks and sorry if this has been covered in another thread already. :D
do you have two monitors connected to the card? If so the card will never fully go into Zero-Core state and idles around 50-60, the core itself has no load but the memory is still clocked at full when multiple monitors are plugged in.
