Here is my current (and old) rig:
CPU: AMD Phenom 9550
RAM: 4GB
MOBO: mATX Generic HP (Has only PCIe 1.0x16 :/ )
GPU: 8800 GTS
PSU: Corsair CX430w
I was wondering if I would be able to throw in a AMD Radeon 7850 and not have any bottleneck on the GPU? If there would be a large bottleneck, what would be a good GPU to get? The reason I ask about a 7850 is because they can be found for a decent price and have a decent amount of performance that I dont believe would be bottlenecked by the CPU. I saw the scrapyard build that Linus and Luke recently did and Linus used a 7850 with a Q6600 which my resaerch says isnt much different from the Phenom 9550.
Thanks in advance!
https://linustechtips.com/topic/320048-radeon-7850/
linus used a 7950......................... the 8800 gts, what one?........... and no matter what card you buy, it will be very cpu bound.
what resolution are you gaming at?  and would you consider a 6670 or r9-250 instead?
I have the 8800 gts with only like 300mb of vram... I usually have dual monitors but when I game I usually run at 720p but my main monitor is 1680 x 1050.
https://linustechtips.com/topic/320048-radeon-7850/#findComment-4350071
( 320 card? - I have one of those ) you're cpu bound. use the card you have.
I get really good performance with it but I would like to play games such as the new battlefield hardline (no need for max settings what so ever) and I read that the recommended AMD cpu is the Phenom 9500 which is actually a little lower in performance than my 9550. My only problem is I only have 320 MB of VRAM and I would like to have a card that performs as well or a bit better with at least 1GB of VRAM.
https://linustechtips.com/topic/320048-radeon-7850/#findComment-4350165
this cpu?
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103251
forget what the halfwits that are selling the game say. you are cpu bound. As I remember going back and thinking through my cards and machines...............if you can get a 7850 for a really good price, buy it.
forgot, I have the 640 card.
https://linustechtips.com/topic/320048-radeon-7850/#findComment-4350268
this cpu?
That is the CPU i have. I found used 7850s on ebay for about $75 is that with it?
https://linustechtips.com/topic/320048-radeon-7850/#findComment-4350325
