whats your gpu
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341405
R7 240
You won't be maxing any current AAA games at 2560*1080 with that GPU
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341431
thats why i said i'm looking to purchase a new one
You said you're getting a monitor. A 970 or a 290/x would do it comfortably.
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341461
a 290x would do better because more memory and more bandwith
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341472
A 290x and a 970 both have 4GB of vram. Nvidia's bus width is lower, but they have tricks to make it take much better use of the bus. They are about the same in both price and performance.
@EntAsia, a 290x will run hotter and take more power though, so take that into account.
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341548
I also second the R9 290X for this choice. A sapphire R9 290X Tri-X or Vapor-X card would be fantastic.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/319411-219-max-settings-aaa/#findComment-4341595
