Hello! I have a question about my build, I wanted to ask if the build would be bottlenecked with the CPU and the GPU as my parts are:
Pentium G3258
EVGA GTX 960 SSC
MSI Z97S SLI Krait Edition
NZXT Kraken x41
Those are the parts that you should need to know, even when the CPU is overclocked the two cores may be a problem in certain games, but what do I know.
I'm fairly new to pc parts in general and anything would help!
https://linustechtips.com/topic/319181-build-help/
highly recommend a r9 280x and a low end intel i5 just can't recommend a dual core CPU, regardless how muhc people are using it without problems
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/319181-build-help/#findComment-4338560
Pentium G3258
EVGA GTX 960 SSC
NZXT Kraken x41
As mentioned above the 960 is a pure waste of money.Get the 280x.And yes the CPU will bottleneck the GPU a little.
https://linustechtips.com/topic/319181-build-help/#findComment-4338593
Thanks for the responses (I was away from home for a while) and i'll see about the R9 280X, is there any that you recommend?
https://linustechtips.com/topic/319181-build-help/#findComment-4342475
I Like the Vapor X edition as it's cooler is fantastic and now after a rebate it's really cheap - http://www.newegg.com/Product/Product.aspx?Item=N82E16814202137&cm_re=R9_280x-_-14-202-137-_-Product
https://linustechtips.com/topic/319181-build-help/#findComment-4343487
