How "low" is your low price?
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/318997-ghosting/#findComment-4336460
why? what would you recommend?
Well, there is nothing special about that monitor over a $120 one.  It is a TN panel, 60Hz, 1080P resolution 250 brightness.
Tell us what you need it for, only gaming?
Tell us what your PC specs are.  Maybe we can fit you into a 144Hz model.
https://linustechtips.com/topic/318997-ghosting/#findComment-4337465
i have gtx 970 but i want some good for competitive like league of legends because i play that game. and minimal ghosting too or 1ms the benq rl2455hm it has 1ms.
https://linustechtips.com/topic/318997-ghosting/#findComment-4337485
Hi guys! Can i ask?
No you may not. Sorry for the inconvenience. :D JK
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/318997-ghosting/#findComment-4337711
