Hi guys,
I have an Acer Aspire 7560-SB416 with a broken screen that I want to replace to use as a media computer but hooking it up to a monitor makes it pointless for what I need. I'm trying to find a replacement LCD but I cannot find a definite replacement for it. I found these:
http://www.amazon.com/Acer-ASPIRE-7560-SB416-Laptop-Screen/dp/B00IGJ1EAC
http://www.laptopscreen.com/English/model/Acer/ASPIRE~7560-SB416/(this one has two different versions)
Any help? Need to buy replacement this week before I get iced in so gotta move fast. :)
https://linustechtips.com/topic/318944-lcd-replacement/
Take apart your laptop and find the product id on the back of the monitor. That will guarantee to work. Otherwise its a guess unless it is written on the seller description that it will work with your laptop. It's not hard to replace the screen, but it will sometimes easy to break some of the plastic so be careful.
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/318944-lcd-replacement/#findComment-4335863
