So i want to make my nexus s faster, i have been told by users that i can make it usable for basic tasks, because right now it is slow as ballz.
I have never rooted, installed a custom rom or launcher, nor used android much. So i would like to know, what should i use, and how should i go about it. I should say that this nexus s is not unlocked(as far as i know) and i would like to maintain the telus compatibility.
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
https://linustechtips.com/topic/318786-nexus-s-romrootupdate/
https://linustechtips.com/topic/318786-nexus-s-romrootupdate/#findComment-4333736
how do i use that, i really have no clue
My Rig
Total: $2074.22
https://linustechtips.com/topic/318786-nexus-s-romrootupdate/#findComment-4333817
Plug in phone. Settings > Developer Options > Enable USB Debuggng, then run that toolkit and press 'Unlock Bootloader.' That should unlock it on its own, do note that it'll wipe the device (back to factory.) From there, you can flash a custom recovery (I recommend TWRP), which is on the second column, then use that to flash a custom ROM. Alternatively, you could follow this guide. If you need help, I'll respond to this thrad; but delayed, as I won't be home until tomorrow.
https://linustechtips.com/topic/318786-nexus-s-romrootupdate/#findComment-4333891
