Yes Yes i know a hackingtosh, but i wanted to try it out for my self and see how it performs anyways so i installed unibeast and booted up and got the screen where you choose your usb then after that it went into an apple logo and a bar down below started loading then half way trough the bar just stops i even tried leaving it for a couple of hours so i am kinda out of ideas and i was wondering if the community could help me out.
Thanks in advance :):)
asus ROG maximus vii gene
pentium g3220 replaced next month with i7 4790k
8gb RAM
gtx 760
corsair RM750w powersupply
120gb samsung ssd
https://linustechtips.com/topic/318661-hackingtosh-problem-help-needed/
when you boot from usb type these things in first
-v -npci=0x2000 -GraphicsEnabler=No
This but if that doesn't work, try going into safe mode with the same exact flags but with an additional -x
Also do some research around and look for other boot flags that might be useful to you as the first time I hackintosh, I had the a rather long line of boot flags in order for it to even boot up properly for the first time.
I have seen this problem when it stops loading half way even on actual imacs.
Desktop: 16gb Ram, i7-2600k, GTX 560 OC.    Laptop: i7, 8gb DDR3, 840m GPU
Server 1 (Files and AD): i3 3220, 4gb DDR3, 1TB Western Digital Blue, Overkill motherboard I got for free (better than main computer) changed to xeon, don't remember exactly what but xeon version of the processor  and 8gb ECC Ram   Server 2 (games): 8gb Ram, i5, Geforce 710m
