How much rpm should case fans be average?
What dbA Does it need to be for it to be quite sound
With the incredible range in quality and performance, you can't really have an "average" RPM. As for "quiet" dbA I would recommend aiming for below 25dbA. If you don't use cheap fans you should be ok. If you find your system is too loud, you can always add in a 7.5V or 5V reducer to force the RPMs to drop. Noctua fans come with the reducers, but they are pretty pricey. Ultimately you need to ask yourself how much you are willing to pay for a "silent" system.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
https://linustechtips.com/topic/318316-case-fans/#findComment-4326851
Around 20-25 db should be optimal and not too bothersome, I'd say that a good couple of fans would cost about $15 average (maybe a bit higher or lower).
If you're looking for something that is literally silent, check these out, they're not too cheap but they'll definitely be worth your money.
http://www.memoryexpress.com/Products/MX43957
https://linustechtips.com/topic/318316-case-fans/#findComment-4326858
I'm in au
https://linustechtips.com/topic/318316-case-fans/#findComment-4326869
1. It depends on the fan.
2. It depends on the tone of the noise. If you're looking at the specs listed, be wary that they're probably bull.
3. It depends on what needs to be cooled, where the fan is placed. If you're looking at the specs listed, be wary that they're also probably bull.
https://linustechtips.com/topic/318316-case-fans/#findComment-4343004
