Help finding a GPU
Go to solution Solved by dragoon20005,
Well the EVGA gtx 750 ti only uses 60w  but I'm not sure how much the rest of my system uses. Is there a way for me to find out or should I be fine?
you can use a PSU calculator to est your power draw I do know the LGA775 dont eat a lot of power but the PSU usually at that time are not 80+ certified and may only output less wattage than the rated power
you can measure the 12+ Volts multiply the Amp to get the wattage for the 12 volt rail
Hello, I'm trying to upgrade my computer with a graphics card but I'm not sure which will run well with my computer.
Some PC specs:
Processor: Pentium ® Dual Core E5700 @ 3.00 GHz
Ram: 4GB
Power Supply: 300w
I was looking at the EVGA GeForce GTX 750 ti but I'm not sure if it would work well or even at all with my computer. Any suggestions would help.
https://linustechtips.com/topic/318151-help-finding-a-gpu/
Some PC specs:
Ram: 4GB
Power Supply: 300w
I would at most get a 750 not even the ti. Or maybe even a r7 260.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324540
Budget and needs
I just want something that is relatively cheap ( Sub $200 ) that can play games at a relatively decent framerate. I am eventually going to do a complete system build once I get a job but for now just want to play casually. Also my monitor has a max resolution of 720p. There are people who told me to get a GTX 750 ti but then there are people who told me it would be bottlenecked by the rest of my system etc. so I am not sure what I should do.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324651
if you are upgrading your CPU and mobo later
just buy a good mid range card now instead of buying another GPU when you upgrade
yes the CPU is gonna vaseneck the GPU but if you are getting the i3 or even i5 CPU then the term vaseneck is null and void
I will suggest getting the GTX960 as the minimum for 1080P gaming
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324879
 What card would you suggest? My PSU doesn't have a power connector for a GPU so I was looking for one that would not require a 6 pin or 8 pin power connector.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324891
either way even with the GTX750Ti
some models will require a PCI-E power plug so you need a better PSU which you can use down the road with the new build
invest in a decent PSU like EVGA 500B or 600B whichever is on offer for a piece of mind
I will hold my breath if the 300watt PSU you got in the PC can power the PC with a GTX750Ti
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324906
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324939
If it comes down to it I probably could upgrade the PSU and I will definitely look into those the EVGA PSU's you reccomended but if I don't need to I'd rather not at the moment.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324953
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4324987
Alright. Thank you for the help and suggestions you provided. I'll look into those EVGA powersupplies as you recommended.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4325067
Is your budget like $150?? You need a better cpu. At least the latest pentium.
My CPU isn't the best but I was going to try and wait to get a new CPU until I go to make a complete PC build in which I was going to go for the Pentium G3258 because I heard it has great overclocking capabilities and performs well and is relatively cheap. My current motherboard is LGA 775 and I am not really sure if upgrading the CPU would be too helpful.
https://linustechtips.com/topic/318151-help-finding-a-gpu/#findComment-4327629
