Overclocking help plz
Solved by C0LL0SS0S,
how would i do it then? I've heard from multiple sources its possible
You would have to go into the UEFI and change the BLCK to 104 or something not quite sure I wanted to do it once but realised even with OC you don't gain a lot with xeons
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting6 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
