1 memory kit or 2 kits?
Solved by Sintezza,
you can buy 2 kits of 4 GB ram yes totaly not problem
As long as timings frequancies and voltages are the same you should be totaly fine.
For example if you like Asrock X99X killer board which is black and red, you would probably also like to have the G.skill ripjaws black 2x4GB and red 2x4Gb modules. Totaly no problem to mix that up.
Just make sure that timings ram, and voltages are the same, you will be totaly fine.
