That's an issue with graphics drivers, you need to reboot the system in safe mode by spamming F8 when you see the splash screen and choose safe mode with networking, then you can go to the manufacturer's website and download the video drivers. You may need a secondary PC if your laptop can't get on the internet because it needs drivers
https://linustechtips.com/topic/317587-bsod-please-help/#findComment-4316622
i uninstalled the driver i had installed and it still done it with the default driver from microsoft, will not blue screen in safe mode only normal mode
PC Specs AMD FX6300 8gb ddr3 Ram AMD 270x
https://linustechtips.com/topic/317587-bsod-please-help/#findComment-4316734
