Red Heatsink Fan
Go to solution Solved by Godlygamer23,
Worth, on 01 Jul 2013 - 9:13 PM, said:
Is it bad to have a fan with an LED on your heatsink?
No. It will have no effect on it from a functional standpoint.
Hey, does anyone know of a 120mm red heatsink fan I can use to replace the regular heatsink fan on my hyper 212 evo(my build is red)?
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/31720-red-heatsink-fan/
Phobya NB-eLoop Fan
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405457
Holy sh*t that was fast, a reply in 5 minutes! Thank you!
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405460
How do you use case fans on heatsinks?
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405472
Yate Loon D12SL-12 like a boss
- Silverstone TJ08B-E - Gigabyte Z87M-D3H - i7 4770k @ 4.0GHZ 1.2v - 16gb Kingston HyperX Black 1600 - Gigabyte GTX 770 OC 4GB -
- Silverstone Fortress FT02 - MSI Z77 Mpower - i5 3570k @ 4.0GHZ 1.09v - 8gb Mushkin Blackline 1600 - MSI GTX 670 PE -
- Lenovo T430 (1600x900) - i5 3210m - 8GB DDR3 1333 - nVidia NVS5400M - 256GB mSATA OS - 320GB HDD-
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405473
You should have mounts to screw into the fan, which in turn snap onto the heat sink. They're black and plastic. You can remove the ones on the stock fan and mount them on your new fan.
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405478
nvm, I don't know what I'm talking about. Nothing to see here, move along.
Edited by unidentical
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405484
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405493
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405503
Thank you!
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405523
Ew LED fans :( One of the only things I have wrong with people's builds...
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405630
Some are ugly; some look good.
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405669
I agree, some can accent a build nicely. I only have a problem when there's 15 of em in a case. And some of the fans are extremely cheap, so people cheap out on the performance (sleeve bearings, low airflow, etc.) just to have purrdy lights.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/31720-red-heatsink-fan/#findComment-405678
