After receiving many complaints on Skype about a "helicopter noise" I have finally decided to seek out a resolution. I am using a Mod Mic 4.0 with an Asus Xonar DG. At random times my microphone will produce these strange noises. The problem is likely not the sound card as I have tested the mic with on board audio and an older creative sound card with the same issue. What could possibly be the problem?
Strange Noise.wav
Strange Noise.wav
https://linustechtips.com/topic/317071-microphone-noise/
attachicon.gifStrange Noise.wav
I've had this so many times.
In my case it was noise out of electric net (it simply doesn't have ground in my house), so I switched my mic to the front input of fractal R4. It solved all this stuff.
But now I'm using a simple XLR mic, connected via berh amp - no noise, perfect sound.
So, try connecting it to the front panel (if it's connected via 'hd audio' cable).
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4309491
Thanks for the advice. I connected the front panel audio to my sound card and am now using the front mic port. I'll report back by tomorrow afternoon or earlier on the findings. :)
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4309557
You can put your system under load and use 'listen from this device' in audio settings. It will give u a pretty much all about mic.
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4309572
After about 5 minutes of running prime95 and furmark at the same time the noise was not replicated. I'll still wait till tomorrow to confirm whether the problem is fixed. Thanks again!
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4309605
your mic gain might be too high, causing audio clippings which might lead to even more problems.
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4309771
Unfortunately the noise is still randomly occurring. The noise occurs even when doing simple tasks such as watching YouTube.
I do have the Microphone Boost enabled on the Xonar DG however the noise occurred on all audio devices. Also disabling the boost is not an option as I can not be heard without it.
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4318356
Then, it's time to try some XLR mic's with mic amp or mixer.
The cheapest option will cost about 90-100$. Or, try 'blue microphones yeti' (usb mic).
I believe, mixer and xlr mic will solve this issue. As for me, usb mic also helped, but I prefer XLR stuff with behringer's amp.
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4319841
How long have you had the mic? If you can still return it, it might be best to. If you cant return it you might try a cheap usb sound card. You can get one for under $10. Also, try out Antlion tech support. Never hurts to ask them why their product isnt working properly :)
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4321834
No need to spend that much $ to fix the problem
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4321837
Great point since everything does lead back to the mic. I have sent in a tech support request, hopefully they can help. I did purchase the Mic within the past year so it is still under warranty.
https://linustechtips.com/topic/317071-microphone-noise/#findComment-4322400
