You can check out our LED strips and controllers  :)  I'll give you a picture when I'm back on my main computer again
LED: http://modguru.net/product/led-strip-rgb/
Controller: http://modguru.net/product/rf-rgb-controller/
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
Neopixels! They're so underrated... here's a strip I'm currently playing with, each LED can be individually programmed, super awesome stuff. Not the cheapest solution but certainly more fun than pre-programmed strips. Plus, you can cut them to size and run them wherever the heck you want.
Neopixels: http://www.adafruit.com/products/1460
Arduino Micro: http://www.adafruit.com/products/1315
Green With Envy
A build based on a children's cartoon
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992011&cm_re=nzxt_hue-_-11-992-011-_-Product
and this comes with 2m of a rgb lighting strip
or for a single color than these would be great option.
http://www.nzxt.com/product/detail/101-sleeved-led-kit-case-accessory.html
otherwise the bitfenix alchemy lighting strips are great too.
