Hi guys,
Just got a Pi 2, looking to use it as a media centre type ordeal hopefully streaming films from my PC upstairs to the TV. Couple of things;
I put a 64GB Micro SD card in, along with a keyboard/mouse, 2A Samsung Tab charger and HDMI cable and the red + green LED were stuck on and I couldn't get anything to output. The SD card was formatted, any help?
Also, what's the best to use for the stuff I require - I heard OpenELEC is a good OS, or "Kodi" (used to be called XBMC?)
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/316764-raspberry-pi-2-problems-questions/
Hi guys,
use raspian for best support.  By formatted what did you actually do... Sounds like a poorly written SD card...
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
I just put it into a card reader using a Micro SD to SD adapter on my PC, formatted it and it was done
It works perfectly in my tablet, no problems whatsoever?
Also, can Raspian do the things I want? (Stream films etc) Ease of use would be very nice indeed :)
IDK but you can't just dump files on an SD card and expect it to boot.  Send me a screenshot of the SD opened on your desktop
Hi guys,
Formatted as in formatted(like wiped n' stuff), or as in flashed the os?
My life is consumed by CS:GO, even though I'm not exceptionally good at it.
CPU: AMD A10-5800K | GPU: Gigabyte R9 270 2GB | RAM: 8GB 1333Mhz HyperX Blu | Storage: 120GB Samsung 850 EVO + 1TB WD Caviar Blue | Chassis: NZXT H230 | Mobo: Gigabyte GA-F2A88XM-HD3 | PSU: Corsair CX500 500W | Cooling: CM Hyper 212 EVO | OS: Windows 10
In order of priority: GTX 970 Strix, 2 good 1080p monitors, i5 4690k, MSI Z97 Gaming 5 LGA 1150, a job
Hi guys,
Umm, you install the operating system to the SD card. That's the only storage the Pi has. I recommed RaspBMC if you're doing an HTPC. It's what I use on mine.
LTT's unofficial Windows activation expert.
Hm, sorry guys - I just followed the quick install guide in the booklet and it didn't say I needed to load an OS as such?
I guess I'll install probably OpenELEC or RaspBMC as you guys suggested
Did you just format the SD card and put it in?
You need to make the SD card bootable. Download (I recopmmend Raspbian) and use the program win32diskimager to mount the Rasbian .img to the SD card.
Rig: i7 2600K @ 4.2GHz, Larkooler Watercooling System, MSI Z68a-gd80-G3, 8GB G.Skill Sniper 1600MHz CL9, Gigabyte GTX 670 Windforce 3x 2GB OC, Samsung 840 250GB, 1TB WD Caviar Blue, Auzentech X-FI Forte 7.1, XFX PRO650W, Silverstone RV02 Monitors: Asus PB278Q, LG W2243S-PF (Gaming / overclocked to 74Hz) Peripherals: Logitech G9x Laser, QPad MK-50, AudioTechnica ATH AD700
What you actually need to do, instead of formatting, is burn an ISO with the desired OS onto it. I think you can use UNetBootin for that purpose but I'm not 100% sure.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
Yeah, you kind of need an OS, it's not like a Pc, it doesn't have a BIOS and such to boot to
Yeah that's what I did, guess that isn't a great idea haha - I'll try Raspbian then!
You expect a $35 ARM-based, passively-cooled, PC that doesn't even have a case to have the OS preloaded?
Or NOOBS, noobs is pretty good.
It's not passively cooled, it just has open chips lol
Or wait does that fall into the classification of passively cooled...
Raspbian is a general OS and basically an ARM version of Debian Linux. What I recommend for streaming is RaspBMC. That even comes with an easy-to-use installer which lets you burn the OS to the SD card in under a minute.
I didn't expect an OS as such, but something like a basic BIOS or so
Guess I was wrong though lol, I'll install something a bit later and report back!
It's definitely not active cooling. And technically it's just cooled by ambient air, which would be passive cooling.
Oh, okay.  Isn't it nice when you learn something new?
ARM doesn't need a BIOS - it can just boot from storage right away. But yeah, it's okay to be unfamiliar with it. Even I was surprised that the Pi didn't have any kind of BIOS.... I once tried booting it without an SD card.
actually - doesnt the pi 2 come with a licence for win10 when it comes out?
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
I'm sure that the user would have to download and install it manually. Keep in mind that the Pi's only storage is the SD card, which is not included.
