I've built online what do you guys think?
AMD fx-8350 8-core black edition
Gigabyte r9-270x graphics card
Corsair Vengeance 8 gig 1600mhz ddr3 kit
WD Blue 1 terabyte
Antec vp-450 450 watt
Corsair carbide series black 400r Mid tower
Gigabyte AM3+ AMD 970 SATA 6Gbps USB 3.0 ATX DDR3 1600 Motherboard
https://linustechtips.com/topic/316571-will-it-work/
Nothing's wrong with it.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302663
IMHO don't get an FX processor, go with a similiar priced i3/i5 and you will be so much happier with performance.
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302702
I would get more powerful psu if you want ocing, but otherwise its all compatible
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302718
It's up to you, intel's got stronger single core performance. AMD's the opposite, they've got weaker single core performance but with more cores.
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302719
WD Blue 1 terabyte
Absolutely nothing wrong with it, I'd change some things though.
Seasonic makes better PSU's in my experiences. Something like this:
 http://tweakers.net/pricewatch/353353/seasonic-s12g-450w/reviews/
I wouldn't get an FX-chip. I have one myself. I built a friend a PC with an i5-4460 and it straight out-performed my fx-8350 in every game. Overall smoother experience. Wait on Zen if you want AMD, I think that'll be worth your money.
I have a Corsair Carbide 500r myself. While it's a good case, it's not worth it's price compared to something like an NZXT H440. I'd rather have 60$ NZXT S340 over my 500R at this point, it's just built more properly.
I don't know how the 400R fares, but I'd put a little more attention to the PSU, CPU and the Case ;)
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302724
Absolutely nothing wrong with it.
Although Seasonic makes better PSU's in my experiences. Something like this?
I'd rather have 60$ NZXT S340 over my 500R, it's just built properly.
I don't know how the 400R fares, but I'd put a little more attention to the PSU and the Case ;)
i dont think ill oc it since it runs at 4ghz stock which is more than enough to run arma or witcher, could you give me a link to the nzxht h440?
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302743
If you're looking to upgrade in future, then FX is not the best option. I really doubt AMD will release anything more decent than the 8350 (PS the 9x series is just an OC'ed version).
With Haswell CPU's the story is different. You can now buy an i3/i5 and in future if you want to upgrade you have plenty of options.
That said, both FX and haswell chips are not bad CPU's by any means.. It's just how you want to make the investment..
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302934
That FX CPU might be a better value though, but when it comes to upgrading.... Yeah, it's not the best option....
PC Specs
Indonesia
Australia
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302946
amd works best for me now because its cheaper than intel and i tend to do alot at once so the multiple cores are good , i dont really see a need to upgrade unless something breaks then id pretty much have to
https://linustechtips.com/topic/316571-will-it-work/#findComment-4302956
Then get intel....mostly you need more RAM if anything for having tons of things open..
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303229
WD Blue 1 terabyte
Also what is your budget ???
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303249
Also here are some graphs...showing how much powerful intel is compared to AMD
Different sources? Sure.
http--www.gamegpu.ru-images-stories-Test
these are really good examples of amd over intel while intel does overpower amd 9 times out of 10 i'd still like to stick with amd due to the fact they cost less than intel and when ever mantel starts getting used more widely amd could easily match intel
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303293
ok I guess....but whatever your money being wasted..
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303332
i dont really count it as a waste i didnt see your other post about my budget im trying to keep it under 1000$ right now as it its a little over 600$ I do know for a fact that intel is more powerful than amd which is what your graphs show me the only reason i went with amd to begin with is due to the fact that they cost less than intel
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303415
I can help you make a great build for 1000$ and stay under.....do you need a OS ? Monitor and etc ?
https://linustechtips.com/topic/316571-will-it-work/#findComment-4303861
