GPU Usage and Temp Question
Go to solution Solved by Nup,
Any other way to clean a PC without compressed air can?
i can't find it anywhere
even on and PC hardware store :|
do i need to do a OCCT test like Veimik said?
i run everything at stock
Yeah I just use a cloth, a small paint brush for cooler fins and my good ol lungs :P
Compressed air does make it go a lot faster though,
Em, i wouldn't. Tbh if the pc hasn't crashed or anything then i would deem it to be ok.
If you really want to be sure put it under one stress tests and if it can run those for a while then there should really be no problem. But since everything is at stock, i wouldn't bother. :P
Iv never hear of that program... so i wouldn't really be able to tell....
When i play CS:GO and not capped my FPS
is it usually jumpy from 60 to 90% usage?
Because sometimes my FPS dropped, between 200-400
is it because many people join, or maybe the GPU load when there's a nade throwed?
and is it normal temps with this FPS
Not Capped FPS = 59 - 63 Degrees
241 FPS or 181 FPS = 56-59 Degrees
121 FPS = 48-55 Degrees
and the VRAM usually reach 1000 ?
My GPU is Gigabyte GTX 970 G1 Gaming
https://linustechtips.com/topic/316503-gpu-usage-and-temp-question/
First of, get this man some Vsync. Second off, those temps are fine, though I don't see how CS:GO makes a 970 go that hard even on those frames.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
The fps and temps aren't really link directly, so to speak.
Those temps are perfectly fine. The reason why you may be seeing more usage on your gpu when you take the fps cap off is because its working to obtain its maximum, as opposed to only doing as much as it needs to get 60 fps.
There are tons of reasons for fps drops, in game demanding sequences could be a reason, yeah.
I presume that your vram "1000" value is in mhz? if so, then yes, perfectly normal, this is the speed it runs at (like the speed of regular ram) :)
Bleigh!  Ever hear of AC series?
Yup, that's okay. It happens to me too. It's just how it works.
With that high amount of fps (which, honestly, you don't need THAT much, up to 200, 250 is far more than enough) it's completely normal.
These are also fine.
What is your CPU btw.?
Desktop:
CPU: Ryzen 5 5600x  | Cooler: be quiet! Dark Rock 4 | Motherboard: Gigabyte B550 Aorus Pro AC | RAM: 2x8GB Crucial Ballistix 3200MHz | GPU: Asus GTX 1070 ROG Strix | PSU: ADATA Core Reactor 850W | Case: be quiet! Pure Base 500DX | HDD: Samsung HD502HJ 500GB | SSD: XPG M2 SX8200 Pro 512GB | SSD 2: Crucial MX500 500GB | Microphone: Blue Snowball iCE | Headphones: Corsair HS70 Wireless | Soundcard: Maya U5 5.1 | Speakers: Genius SP-HF1800A | Phone: Samsung Galaxy S10
Secondary Desktop:
CPU: Intel i7 4770k @stock | Cooler: Cooler Master Hyper 212 Evo | Motherboard: Asus Z97-PRO (Wi-Fi AC) | RAM: 2x8GB 1600MHz DDR3 | GPU: Asus GTX 1070 ROG Strix | PSU: OCZ ModXStream Pro 700W | Case: SilentiumPC Aquaris X70W | HDD: Samsung HD502HJ 500GB | SSD : Corsair Force LS 240GB
ASUS ZenBook Pro UX550VD:
CPU: i5-7300HQ | RAM: 8GB DDR4, 2400MHz | GPU: GTX 1050 + Intel HD Graphics 630 | Storage: 512GB M.2 SSD
Oh i see
i'm just worried because the temps is so much higher then maybe a month ago
don't know if its the ambient or dust or maybe both :|
I see :)
Yep i capped my FPS to 121
i just want to test if my GPU works correctly and i want to check the max temp.
my CPU is i7-4790
so you play CSGO ?
i want to ask
why is when i capped the FPS at 121
i usually get 117-119 FPS on net_graph 1 ?
Use OCCT for that. You can test both CPU and GPU there, it's a cool program.
Well, honestly... I have no idea :P It just works that way I guess.
Desktop:
Secondary Desktop:
Oh i see
Ambient temps and dust would do that :P
Seeing as that its winter (At least over here) the heating may be going up :P its does add a good bit.
I dont think that there should be too much of a difference from dust, how long have you had it? and what case do you have? is it filtered?
So the OCCT will tell me if my hardware is faulty or not?
I'm just too lazy to do the test haha :|
Emm
I bought it 1.5 month ago
my case is HAF Stacker
yes its filtered
and i'm using 2 AF120 intake fan at the front
and stock exhaust fan
and CPU cooler is Hyperx 212 Turbo
Emm
yes its filtered
I don't think that dust would do much harm then.
Do clean your case a couple times a year though :)
Must be the heating :P I wouldn't worry too much bout it. so long as it isn't a crazy spike up in temp then you should be all good.
Well, if there were no glitching or anything in the 3DMark test, then you don't have to do it, I guess. Also, you're runing at stock, so that should be perfectly fine.
Desktop:
Secondary Desktop:
Good ol lungs?
so blow it?
is that okay?
if u drop a saliva , then it will be dead right haha :P
Oh i see
thank you !
Good ol lungs?
so blow it?
is that okay?
Oh i see
thank you !
unless you drool like no ones business in its fine, just a little wipe will do the job :P
yeah, i tend to brush the fans then blow on them and it will displace all of the resettled dust from the brush :)
lol
hahaha
okay thank you so much ! :)
